04-05-2007 05:09 PM
04-06-2007 03:14 PM
04-09-2007 12:54 PM
04-11-2007 04:28 PM
04-12-2007 12:22 PM
****Solution*****
Hi Allison,
I tried a few times to repair and uninstall/reinstall the software with no luck. POI: The original problem came about when i upgraded to the latest version.
I found that if i uninstalled the software in safe mode and manually removed the NI data from the application data folder and the c:\program files ... as well as removing the National Instrument registry components for the cwimaq and then reinstalled the driver then everything works with Visual Basic again.
Jomile
04-13-2007 03:38 PM
Jomile,
Great! I'm glad to hear it. Let us know if you have anymore questions, and hopefully this will all work out for you from here on out!
-Allison S.
Applications Engineering
