Accelerometer-C# C++ Ask for tutorial for beginer
Hi Everyone.
I'm a university student. Now I have a project that need to make a new application to get and calculation data from accelerometer such as: geophone, accelemeter, hammer...
I'm aking for example, or tutorial or code.... (something like that). I can get the data from those accelerometer buy useing labview, then I can make a new c# application to calculate the data. However, I need to make a new application which comebine 2 of those requirement by myself to complete my project.
I can make an ni daq application via measurement studion in viasual studio 2010. however, I just only get and export data into 1 grahp(auto code from the measurement studio). It is very inconvinience.
Somebody can help me about this problem.
Thank you in advance.
(4,774 Views)
Hello, PaiChai
Are you working with the NI-DAQmx C# examples already? If so, which ones have you used? What specific questions do you have about the code?
Daniel Dorroh
(4,730 Views)
Thank for your reply. I'm using Ni cdaq-9184 and Ni9234.
I has already learning example in measurementstudiovs2010/dotnet/example/daqmx/analog in/measure acceleration folder.
I want to get the data from 2 accelerometer and hammer in the same time. If I using a waveformgrahp tool in toolbox. I only get 1 frequency signal of 1 accelerometer. I can not (or I don't understand how to use it) to get the second frequency signal of the other accelerometer and the hammer.
Do you have any suggest for me.
Thanks alot
@D-Cubed wrote:
Hello, PaiChai
(4,710 Views)
Hi, PaiChai
I have a few more questions for you:
  • How are you building your UI? Are you using Windows Forms controls, WPF, or WebForms? Plotting will differ based on which technology you are using.
  • Are you currently able to configure your NI-DAQmx tasks to retrieve the data you want?
  • Do you have any snippets of code about which you have particular questions? How are your tasks currently configured?
Daniel Dorroh
(4,666 Views)
I'm using winform.
It can get the data from 1 accelerometer perfectly.
But 2 accelerometer, i can not plot it into 2 diferent grahp.
(4,630 Views)
Can you post the code you are using to read from your DAQ channels?
Daniel Dorroh
(4,558 Views)
