I'm running into an issue where the AISupportedMeasurementTypes function (of NationalInstruments.DaqMX.Device) is returning way more options than seem reasonable. For example, when I request this from a NI 9239 module, I get 10 options, including Thermocouple, VoltageCustomwithExcitation, and Current. I do not believe that any of these options are valid. I see this with some other modules as well, including NI 9218. I am currently using the library with a version of 15.5.45.109, which I believe is the latest (or it was a month or two ago).
Has anyone else seen this behavior, and if so, is there a "workaround"? I want to limit the user's choices to only valid selections, but this seems to be a major issue! Any ideas would be very welcome!
