12-09-2010 01:10 PM
ı have a DAQ cart.ı and want to use with visual studio c#. ı have installed the driver and Measurement Studio but ı cant creat a NI DQA Windows Aplication. only NI class library and NI Windows Aplication. How can ı solve this problem
Solved! Go to Solution.
12-10-2010 11:45 AM - edited 12-10-2010 11:45 AM
Howdy Omer!
Make sure you install the DAQ driver after installing Measurmenet Studio. The DAQ driver is what installs the DAQ Windows application template. It won't install that component unless Measurement Studio is already installed.
12-11-2010 02:34 PM
thansk.
but,
my problem isnt solved yet. my problem is that, when ı intalled DAQmx driver and Measurement Studio 2010 some dll file isnt install .this are NationalInstruments.DAQmx.dll,NationalInstruments.DAQmx.msl,NationalInstruments.DAQmx. ı cant find them in the file C:\Program Files\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\Current
12-13-2010 10:39 AM
Hi Omer,
When you install the DAQmx driver make sure you select the components relevant to Measurement Studio for installation. Also, make sure you are installing a recent version of DAQmx.
