Hello!Every masters!
I want read the CSV data and change to waveforms,
then take yellow waveform voltage above 1V ,make a trigger,
At is time,start to calculation the green waveform the pulse wave number,
when the yellow waveform arrives at voltage above 1V, the stop calculation is green waveform。
Then now the should revision this program?
At present already might will the CSV data changed to the waveforms,and attempts by example "trigger count" makes the revision, but is unable to measure in the scope the green pulse wave number.
* non-immediate dynamic measurement 。
index is 1, length is 5。
The data and are the present program like appendix。
Please the masters to help me to have a look to revision?
Thanks!
