Measure
Why doesn't my NI DAQPad-6015 see the signal on sc-2345?
I want to measure the changes of current on the pressure indicator. For this purpose I use module SCC-CI20 in my sc-2345 connected to the computer with NI DAQPad-6015.
In MAX all the devices are displayed correctly, but, when I start the process of measuring there are only strong scattered interference noises on the display, and it seems like the signal from the pressure indicator doesn’t go through DAQPad-6015 .
I think that the problem is that NI DAQPad-6015 cannot identify or see the signal on sc-2345, but I don’t know what to do to solve this problem.
(5,371 Views)
Hi Leonid.Rybalkin,
What range of currents are you inputting from your transducer?  Also, are you doing your measurements through MAX?
(5,347 Views)
yep
When the circuit is closed, I connect the tester to the module, and everything is displayed correctly. Here are the pictures of the work.
1 image : DC 15V 100mA - off
2 image : DC - on
(5,342 Views)
I took a look at the manual for the SCC C120 (http://www.ni.com/pdf/manuals/371068b.pdf) and based on page 6, it looks like it has a recommended maxiumum input current of 20 mA.  That may be the cause of any unusual behavior
(5,312 Views)
