10-16-2014 04:25 PM
I got this message when setup the NI 9205 before reading data from it
DAQmx Error: Device to which the sensor is attached does not have an available internal excitation source.
Select another device with an available internal excitation source or supply external excitation.
Channel Name: NI9208
Device: cDAQ9181-196FCE5Mod1
Task Name: _unnamedTask<0>
Status Code: -200161
10-17-2014 02:22 PM
Hi robui,
I think the error you are experiencing is similar to the one discussed in this forum post: http://forums.ni.com/t5/Signal-Conditioning/SG24/m-p/239213
Make sure you are selecting the analog input on your DAQ Module (NI 9205), and not the one on your cDAQ chassis (NI cDAQ-9181).
