01-18-2013 04:41 AM
Dear National Instrument Team,
I received an equipment from US and 2 same National Intrument card are mounted on it. The reference are CB-68-LPR (1847000-01L).
The equipment was built in US that means it works with a power supply of 110 Volts.
As I work in Europe, I would like to use it with the European electricty network that means 220 Volts.
Could you please give more information on these products CB 68 LPR? I would like know what is the power supply (input 24Volts?) . I only received the equipment without information on electrical components.
Thanks in advance for your support,
Céline Daniele
01-18-2013 10:38 AM
You've posted to the wrong board. This is for a old product called Measure.
The CB-68LPR is just a dumb terminal block so your question about the 24 volts does not make much sense or the comments about 110/220. Just enter CB-68LPR into the search box at the top of the screen if you haven't already done that.
