02-26-2016 09:19 AM
Hello!
I'm working in a proyect. Where they form an Array in 2D with data in X and Y (see picture). I need that for each iteration, the data being stored in a MS Office Report in Custom excel. But this doesn't occur, only keep latest data of latest iteration.
Sorry for my English.
Thanks....
02-27-2016 07:00 PM
02-28-2016 07:58 PM
of course...
02-28-2016 09:11 PM
02-29-2016 08:32 AM
I checked this, but the problem is in MS office report where i need that the data saved for each iteration in same excel. For example for first iteration the data are stored as the picture attach, it's ok!. But i need that all data of each iterations, in order, using as a reference a custom excel. Now, the data are saved for each iteration in a registry of excel...
thank you very much!!!!
02-29-2016 09:19 AM
02-29-2016 01:11 PM
the problem is ¿Why insert previous data? and for finally all data saved...I made a program type for model the specific problem...
look this VI...
03-01-2016 10:44 AM
Hi Ange,
Are you trying to append to a file? Are you trying to put all of your data in one excel file? Or are you trying to write to a new excel file after each run?
Have you tried to use the Write to Measurement File express VI?
Thanks!
03-02-2016 07:13 AM
I'm trying to ... create a file (custom excel) and save all iterations in the same file in different cells and defined...
I tried with Write To Measurement File but the problem is in the position data for each iteration.
03-03-2016 10:15 AM
Hi Ange,
If you have the Report Generation Toolkit, this document shows how to append data to an excel file between each runs. It is a good example and you should be able to implement the code easily into your own program.
https://decibel.ni.com/content/docs/DOC-3404
If you do not have that option, there is also a great forum post that has solutions listed for your problem. There are several solutions on there that you can also implement in your own code.
