07-16-2013 07:42 PM
I'm running an experiment with a MEMS variable capacitor device. I want to minimize the parasitic capacitance of the electrical connections and wires. What kind of wires should I make my connections with? Stranded wires, solid wires, coax cables? My devices have 50pF or less capacitance, so my measurements will be off if there is a lot of stray capacitance from the set-up.
07-17-2013 07:20 PM
Hello John,
Is your variable capacitor differential or not?
Regards
Frank R.
07-17-2013 07:41 PM
When I'm characterizing the capacitor, one end of the capacitor is to ground. When I'm using the variable capacitor in other set-ups, it's differential.
07-18-2013 07:57 PM
Hi john, sorry for aask you again before give an answer but, I would like to know first what kind of "MEMS variable capacitor device" you have, do you have a model number or its name?
Regards
Frank R.
07-18-2013 08:58 PM
07-29-2013 08:54 PM
John,
The truth is that I do not see a big difference between these options if you are talking about parasitic capacitance. This cable is going to be part of your connection to a different device, this is not part of your PCB (where it is a big deal), so I really do not see a difference. However if you have the option of using coax connections to the PCB, go ahead.
Regards
Frank R.
