NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Louwrence Ngoma
Measure signals from Matlab Simulink Model
I modeled a six bus power system network on Matlab/Simulink and I would like to measure the voltage and current signals using a DAQ card. The DAQ card im having is a
NI PCI-6132 S Series Multifunction DAQ. How do I go about acquiring this signals?
Louwrence
Member
Joe Steak
Re: Measure signals from Matlab Simulink Model
Hey Louwrence,
Are you going to be using the 6132 card with LabVIEW to acquire the signals? If so, you should look in the NI Example Finder that is installed with LabVIEW. Go to Help>> Example Finder. Then go to Hardware Input and Output>> DAQmx>> Analog Measurement and choose the example you would like to look at.
If you are trying to use the card through MATLAB, you will need the DAQ Toolbox. You can check for official compatibility here. I do not know what is installed with this toolbox as it is not National Instruments. There may be some examples in there however.
Hope this helps.
MATLAB®, Real-Time Workshop®, and Simulink® are registered trademarks of The MathWorks, Inc.
Joe S
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
