NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
JessicaM
Measure Add-in won't install in Excel 2010
I've used Measure 2.0 on other computers successfully, including one running Excel 2007 with the VBA converter pack.  However, I cannot seem to add it to Excel 2010.  It is listed and selected in the Active Add in list, however it does not show up in the Add-ins menu with my other add-ins.  Any suggestions?
thanks
Member
NathanS
Re: Measure Add-in won't install in Excel 2010
[ Edited ]
Hi Jessica,
I am sorry to tell you that unfortunately, the Measure product reached it's End of Life date back in 2009, prior to Excel 2010. Please see the product page here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/1450
Nathan S.
Member
JessicaM
That's too bad it reached its EOL.  Fortunately, it does still work in Excel 2010, you just need to install the VBA converter hotfix correctly:
http://support.microsoft.com/kb/926430
Once unzipped there is a readme file that specifies which files you need to move.  Turns out I had just forgotten to move one of the files.  Once all the files are moved and the VBA modules are migrated, then Measure still works great in Excel 2010
Member
WhiteWater
Hi JessicaM,
Im facing a similar issue now as well. How did you get the gpib and serial xla files migrated?
thanks
Member
JessicaM
We only had to migrate the VBA code, not the actual serial or gpib tasks that you set up within the add-in.  To migrate the code, you just export and delete each module, then import it back it
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
