10-17-2014 03:38 PM
I am completely new to using anything NI and have a very basic question. I am collecting acceleromter data with 9233 cards in a cDAQ 9172 chassis and viewing the live data with Measurement and Automation Explorer Version 14.0.0f0. I would like to log raw test data to disk, I assume this is the TDMS file. In the Data Neighborhood, NI-DAQmx Tasks, My Task, I am viewing the Logging tab and and set up a file path to a local directory. I start and stop the run with the buttons at the top of the graph, but nothing gets logged to the directory.
There is a note that says "No data will be logged when task in run in this dialog. Configure logging and then use the task in a development environment to begin logging to disk." All I can discern is that it won't log, but I have no idea what the rest means.
Is there a simple way to create a TDMS file on my hard drive so that I can import it into a data processing software?
Thank you,
Jeff
10-18-2014 03:42 AM
