NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
andreamb
Is there any incompatibility between Labview 8.5 and Traditional DAQ?
Hi,  I`m using a DAQPad 6020E and the Labview 8.5 Daq assistant don`t detecte my DAQ when a try to create a new task (to create a new virtual chanel). But MAX detect the DaqPad. So, is ther any incompatibility between Labview 8.5 and traditional Daq? Do you know how can I resolve this?
Thanks.
Knight of NI
Dennis_Knutson
Re: Is there any incompatibility between Labview 8.5 and Traditional DAQ?
First, you posted to the wrong board. Measure is an old add-on for Excel.
Second, there is no incompatibility between LabVIEW 8.5 and tradtional DAQ. There is an incompatibility between traditional DAQ and DAQmx which is what the DAQ Assistant uses. Make sure that you install DAQmx if your device is supported by it. Otherwise, you will not be able to use the DAQ Assistant.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
