Measure
Instrument Driver for Hommel-Tester T2000 (Surface Roughness Profilometer)
I am using a Hommel-Tester T2000 Surface Roughness Profilometer with data output via printer only.
No I would like to implement electronic data output via the RS232 serial port.
Does there exist a software solution providing this quite simple feature?
Thank you.
A.G.
(7,413 Views)
You've posted to the wrong board. Measure is an add-on program for Excel.
There is no driver from NI. You can create your own driver or use the Instrument I/O Assistant. You need to get the programming manual from the vendor.
(7,408 Views)
Thank you.
(7,398 Views)
