NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Morti
Input Voltage Measuring
Hi expert
I am using NI USB-6341 to measure the voltage, I used the sample VI ( please see the attached file) one thinng I check the result by the signal from power supply, unfortunetly they are not the same, Does any one know what is the problem? . how can I write a simple program to measure voltage? and what teminology I need to learn to become more familar with measuring
I appreciate any help
Morteza
Knight of NI
Dennis_Knutson
Re: Input Voltage Measuring
The first thing to realize is that you posted to the wrong board. Measure is an old NI product - an Excel add-on.Post to the Multifunction DAQ board.
In you code, you are not setting the infput configuration - i.e. differential, single-ended, etc. Provide details on your connections from the power supply to the DAQ device and look at the recomended connections in the manual. You also need to provide details on what you mean by 'they are not the same'. Is the difference volts, millivolts, or what?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
