10-06-2013 03:51 PM
good morning,
i'm using Pic 16f887 to read 14 adc channels(Pression , temperature and humidity ) , i send them via rs232 to Labview
I have always a synchronization problem between labview and isis 😞 the running interrupts when it receives a wrong string's lenght (my string contains 84 character )
help please
10-07-2013 02:59 PM
Hi asmahamdaui,
What is your application doing with regards to synchronizing LabVIEW and ISIS?
Also, just as a general programming technique, you should open and close VISA sessions outside of the while loop.
10-16-2013 12:20 PM
You should not be posting your question to this board. The product 'Measure' is an obsolete add-on for Excel - you are using LabVIEW. You should post to the Instrument Control Board.
p.s. It makes no sense to set the Enable Termination Character to true with the VISA Configure Serial Port and to also use the VISA Bytes at Serial Port.
