I am using PCI-6229 and trying to develop a code that can generate a TTL/square function signal as soon as one analog input satisfies following conditions: 1. Crossing a certain value (say, 0 V); 2. Falling edge slope. The time delay between the crossing point and newly generated TTL/square signal will be critical in my measurement, and it should not exceed 1 millisecond. Any suggestion on it? Thank you in advance!
Are you actually using the Excel add-on called Measure? That is what this board is for. Otherwise, you should post to the Multifunction DAQ board and mention the language that you are using.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
