08-16-2016 09:58 AM
Hi guys,
I'm trying to measure ambient pressure and temperature within a wind tunnel with a BMP180 sensor(https://cdn-shop.adafruit.com/datasheets/BST-BMP180-DS000-09.pdf) and an NI USB-6343. I'm quite new to labview and I'm not sure how to do this.
Most forums recommend using arduino cards which I don't currently have.
Help would be much appreciated 🙂
08-17-2016 04:39 AM - edited 08-17-2016 04:42 AM
Hi there,
An arduino would be a good piece of hardware for this. You have a few options for programming it;
1) Write arduino code and interface with LabVIEW via VISA Serial interface;
Hooking up the BMP180 to the Arduino
Reading serial data from arduino in LabVIEW
2) Use the LabVIEW LINX library to interface directly with the arduino - The Makerhub is a fantastic resource for many other projects too.
I hope you have found this useful!
-Michael
