NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
fu007
Accepted Solution
GPIB卡連接兩台儀器做測試會發生time-out,發生的時機為偶發
你好以下是我的測試系統
tester:IP750
L/S: ITOS
handler:epson-7000
當tester GPIB 488.2分別連接L/S and handler ,測試中會偶發性GPIB time-out,而tester 得到GPIB time-out 為L/S端time-out
實驗1:不使用handler傳輸訊號以壓測loop 1000次接不會GPIB time-out
實驗2:upgrade tester and L/S connect driver(Teradyne OEM) the GPIB time-out 變成可忽略並不會導致GPIB driver disconnect(L/S) from measure.
實驗3:更換tester backup HD,GPIB time-out 跟實驗2一樣,說明與upgrade driver 無關
問題1:以前在測試這個產品,好像只發生一兩次,中間客戶的程式有更改版過三次,最近有說明GPIB 的寫法都是一樣的,請問這個time-out 是不是會越測越頻繁?
問題2:tester GPIB 連接兩個儀器,是不是需要安裝什麼穩定的程式?
問題3:handler 系統為windowNT ,其他兩個為windowsXP,是否就是這個系統不同造成的?若是的話怎麼以前不會發生,是否有其他方法解決
問題4:以前你們有爭對客戶解決過類式的問題?
Best Regards
KYEC/Lewis #0919150110
Knight of NI
Dennis_Knutson
Re: GPIB卡連接兩台儀器做測試會發生time-out,發生的時機為偶發
Really, really wrong board.
Member
fu007
回應: GPIB卡連接兩台儀器做測試會發生time-out,發生的時機為偶發
Tester  我已經換過兩個IEEE488.2
L/S我換過三張GPIB,另外還換過一台PC
真的不知道該怎麼解決,請問有更好的建議??
Knight of NI
Dennis_Knutson
Re: 回應: GPIB卡連接兩台儀器做測試會發生time-out,發生的時機為偶發
This board is for a product called 'Measure'. It is an add-on for Excel. I have no idea what you are asking except it is somehow related to a Teredyne tester and GPIB, but there is a GPIB board and language specific boards that you can post to if you do not speak English.
Member
fu007
Thanks for your idea,because the teradyne vendor no idea for this issue.
So i request the NI company to solve.
Some ifo below,if you have some idea,please tell me.
Member
kcoggins
Member
Meng-Shiang.Lin
你好,
我也在Epson hanlder NS6040上遇到一些問題,可以請教你GPIB連接的問題嗎?
謝謝。
Adam
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
