07-31-2009 04:49 PM
Hi everybody,
I'm actually working on labview, programming an acquistion card "DAS 4020/12 trigger". It's an acquisition card with 4 channel+1 trigger
All works good onely my trigger which want to absolutle trig on the chanel n°0. (so i have 3aquisition chanel +1acquistion&trigger instead of 4 acquistion +1trgger)
To prgram it, i use labview+universal library...
I give you thanks for all help you could give me
awawa
Solved! Go to Solution.
07-31-2009 08:25 PM
You have posted to the wrong board. This board is for an add-on to Excel called Measure. I would suggest you post to the LabVIEW board.
You might also want to attach whatever code you have already written along with a bit more explanation of the exact nature of your problem.
