Hi all,
I've been working with Vision Assistant 2013 for a week or so. When I first started, I could see the full 2048 x 2048 image from the Camera Link camera.
After some research and investigation, I decided that I needed to reduce the size of the image from the camera. I changed it to 800 x 700 pixels.
Vision Assistant 2013 was still working for me.
I tried a couple of filters, exported some LabVIEW, everything was working well.
The other day, as I was working with the Vision Assistant, I acquired another image from my camera, as I had been doing.
Unexpectedly, the image displayed was only 25 pixels by 25 pixels. This was not a zoom problem, but actually the number of pixels captured.
When I go to MAX, and selected the indicated camera, I get the full 800 x 700 pixels.
When I run my LabVIEW application, I get the full 800 x 700 pixels.
When I run Vision Assistant, I get 25 by 25 pixels.
I'd like to use the Vision Assistant to investigate other filters, manipulations, edge detection, etc.
It is a very useful tool, but not when it is only capturing 25 x 25 pixels.
Has anyone else seen this behavior?
I'm using an NI PCIe-1433 frame grabber card.
I'm also using a Point Grey Gazelle camera.
I don't think it's hardware related, as MAX and the LabVIEW app are working correctly.
I did an uninstall/reinstall without any change.
Any thoughts?
Jeff
