08-27-2015 12:21 PM - edited 08-27-2015 12:23 PM
hello
i want to set a webcam in vision Acquisition express but when i click on usb webcam (correctly work on ni max) recieve this error but with the laptop webcam didnt recive error !! Whats the problem ?!!
i have installed labview 2014 and i think vision Acquisition toolkit is 2013
08-28-2015 12:01 PM
Hi Ramin71_LY,
Are you trying to access the USB webcam from both NI MAX and the Vision Acquistion Express at the same time? You will only be able to access the camera from one location at a time. Does this error appear when you select the camera in MAX or when you try to do a 'snap' or 'grab' from the camera in MAX?
08-28-2015 02:53 PM
08-31-2015 10:07 AM
I'm assuming you have found the examples within the Example Finder. In LabVIEW navigate to Help>> Find Examples.
Hardware Input and Output>> Vision Acquisition>> NI-IMAQdx
There is a Grab (Express).vi in that folder which uses the Vision Acquisition Express VI. Are you configuring the Vision Acquisition Express VI in your application similar to the LabVIEW shipping example?
09-01-2015 12:26 PM
i found example in ni folder examples a ran one of vision ex . i used grab block instead vision acquisition , thanks . i think there is problem in vision acquisition 2014 , i wanted use 2013 version but i used grab function and my problem solved with this
