04-21-2017 12:07 PM
Hi everyone,
I am making a program in labview to record a video for certain time (let is say 1h). When I run my program (attached below) I just get one image instead of a 1h video. I do not why, any ideas?
04-21-2017 03:54 PM
Your VI works fine for me. When you run your VI, do you see the AVI file on disk getting larger over time?
04-21-2017 04:09 PM
Oh that is surprising, when I run it I just get an image. I will try in another computer then.
So the file does not get bigger with time, it just has the size of a single image more or less. It does not increase with time.
04-21-2017 04:17 PM
Is your camera actually acquiring multiple images? Wire the buffer number output of the Grab subVI to an indicator and make sure that number changes over time.
04-24-2017 03:28 AM
Hi, sorry for my late response but I do not have access to labview during weekends.
I created an indicator as you said and it changes over time but still I have the same problem. I obtain just one image instead of a video.
The camera when it is used with apropriate software acquires video.
04-24-2017 03:39 AM
Sorry, I figured out what happened. I had the block diagram opened with the bulb on. That slows down the program so it did not acquire the video properly I think. Thank you for your help.
04-25-2017 09:12 AM
Hello again,
I still have problems with this program. As I said, now it records a video but every second there is like a lag on it (the video stops for a bit every second). Besides, intuitively I can see that I do not capture all the frames.
I tried a producer/consumer program but I do not know how to make it work with a video acquisition (I have never used this type of structures before).
Do you know how can I solve this?
