04-12-2017 11:56 AM
I want to use only one parameter of the indicator edge information in the block vision assistant, so I used unbundle by name, but it tells me wire broken, how can i solve that,
thank you
Solved! Go to Solution.
04-12-2017 01:04 PM
so i find solution in this post: https://forums.ni.com/t5/Machine-Vision/How-do-I-get-the-Position-Cluster-Information-from-Calibrate...
just i don't understand why a for loop can solve that!
04-12-2017 01:34 PM
04-13-2017 12:55 AM
The output which you are receiving is array of cluster data.
-So when you use for loop by default for loop uses auto indexing hence you get one element(Cluster) which you can unbundle.
-Read about for loop and basic LabVIEW tutorials available:
LabVIEW Graphical Programming Course
04-13-2017 05:08 AM
