Hi all,
I'm running two uEye USB cameras in parallel, with mixed results. When I first open the program and plug in the cameras, it runs perfectly 80% of the time (sometimes it just opens one camera instead of both). However, if I stop the program and then run it again, it doesn't work, just thinks for half a second and then ends itself (not initalizing correctly maybe?). To solve this, I have to unplug one camera, run the program, stop the program, and plug in the second camera. Now it will work again -- but just once, then I have to go through the whole routine again.
I'm a real beginner, and I don't know enough about computer science to troubleshoot this. It seems to me that there could be some memory dump that's not happening at the end of the run, or maybe a buffer that isn't being emptied. What do you think?
Anne
