05-18-2016 04:43 PM
Hello everybody,
i want to take two consecutive distance measures, let's say that first one is A and second one is B and then i have to do A/B
please find below the program
Solved! Go to Solution.
05-18-2016 07:21 PM
here is solution check this vi
05-19-2016 06:36 AM
Hi hatef,
i need to take two measures A and B so i can use the value of A and the value of B and do A/B , in the program that you sent, only the current value you can use and the previous one it's cleared
05-19-2016 10:20 AM
you need just use shift register for this one
see this image and do it for your line lengh wire data
05-19-2016 10:31 AM
hi hatef ,
all what i need is saving the previous measure value " A " and divide it with the new measure B
05-19-2016 10:39 AM
this is two method for your request one with holding ctrl and plot two line roi
second without use ctrl for line
see two of them and choose with is better for you
best regards,
Hatef
05-19-2016 04:17 PM
than you hatef
