You need to specify "Grayscale (SGL)" datatype as input in the IMAQ Create function since you are processing the data as float.
Leaving the input blank, I think the default is "Grayscale (U8)", so if you use the U8 output in the image to array function, you should see the output...
Why do you need such a large border size -> 1680 pixels?
K
https://decibel.ni.com/content/blogs/kl3m3n
Kudos:
Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
