10-10-2013 06:27 AM
I am doing a project in image processing,i would like to know what is sliding window technique and purpose of using it in image processing?.
Thank you
10-10-2013 06:53 AM
in image processing a sliding window technique is a technique of moving a window along the image, where some image processing is performed on the underlying sub-image. For example image convolution uses a sliding window. Or pattern matching.
See the simple attached example.
K
10-16-2013 03:57 AM
This link may be helpful.
http://docs.opencv.org/doc/tutorials/imgproc/histograms/template_matching/template_matching.html
