NI Home
Cart Cart | Help
You are here:
Reply
Member
masoudk1368
show ni vision assistant tools in vb.net
Dear All,
       I have a testing project for distance calculating.
I have done this project in Vision assistant 2011 software and I create the vb.net 2008 project through Vision assistant 2011.
My problem is as below:
I need that the clamp tools or other tools to be shown in vb.net in defiend part as you can find in attachment.
We used 2 pictures in vision assistant as you can find in attachment.
Note :  To run the vision assistant project correctly, you need to save this 2 pictures (up.bmp and down.bmp) in c:\c\up.bmp direction.
Please send me the code that show us the used tools (for example: clamp) in Nationalinstrument.vision.imageviewer component (vb.net 2008) after detection.
Your kind reply will be highly appreciated.
Best Regards,
Active Participant
JérémyC
Re : show ni vision assistant tools in vb.net
What do you mean by "I need that the clamp tools or other tools to be shown in vb.net"?
Do you want to show the elements drawn by the Vision Assistant in the "Form1.vb" of your VB project? Somewhere else?
Jérémy C.
National Instruments France
Journées techniques : du contrôle d'instruments aux bancs de test
Du 4 au 13 juin : Grenoble - Pari...
Member
masoudk1368
Re: show ni vision assistant tools in vb.net
Hello. Thanks for your reply.
 You are right. As you told, I want to show the elements drawn by the Vision Assistant in the "Form1.vb" of our VB project.
You can find one of this elements in attached picture ( red border ).
Best Regards,
Active Participant
JérémyC
In fact, what you're trying to do is like importing the tool of Vision Assistant in your VB project which means once the tools would have been converted in VB code, Vision Assistant should be useless.
I'm sorry but using tools of Vision Assistant in a VB project converted from a Vision Assistant sequence is not possible.
Jérémy C.
Member
masoudk1368
Hello
please check the attach file and inform me if it is possible.
thank you
Active Participant
JérémyC
It seems that some of the tools' results are drawn on the picure. It also seems that only the last step in the .vascr is drawn.
I join an example. Tell me if it is what you would like to see in the form of your VB .NET project.
Jérémy C.
Member
masoudk1368
in your vision assistant project you use the clamp (rake) and max clamp tool . i need to show all of the tools that detected in picture in vb.net
thank you
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
