Hi all,
I have a 2D image, i am trying to extract a suitable ROI from an image, smoothen the extracted image
I am using IMAQ Convolute VI which uses Linear filter for smoothing the image.
I am WA Multiscale Edge Detection VI to extract the edges of the signal.
Using the Edge data i am doing curve fitting (2nd order polynomail curve fitting) using MATLAB script node.
Finally i comapare the curve fit data with the designers reference data.
The problem i am facing here when i do the comparison, the error difference is large at the edges of the curve when compared to the centre of the image. (accetable error range is 1um). i am getting it in the range of 4um at the edges.
I need help regarding,
How to sharpen the edges of the image?
Can i apply Bilateral Filter OR Anisotropic Diffusion filter using LabVIEW?
I apolozise since i cannot share any kind of data due to security resaons.
Any help would be greatly appreciated.
Manjunath Kamasani
KM
