11-11-2014 08:08 AM - edited 11-11-2014 08:09 AM
is it possible to save the histogram data from "measure colors" into an excel file automatically?
I need the values for every color plane from 0 to 255. The problem is, that the images which I am actually analyzing do not have a normal distribution of the colors, so for me it is not possible to calculate with standard deviation and things like that.
In "Vision Assistant" --> "Histogram" it is possible to save the data from the graph directly into excel, but only manually. The point is that I want to analyze some hundreds of images and so this would be a very laborious way to do that...
Thanks for your help and kind regards,
Tom
11-12-2014 03:34 AM
Hi Tom,
do you want to automatically export the data from LabVIEW? Just making sure.
What function do you want to use? I can't find a function that is called "measure colors". What data type does the data have that you want to export.
Maybe you could include an example?
Anna
11-14-2014 02:28 AM
11-14-2014 04:02 AM - edited 11-14-2014 04:05 AM
@annaei
Sorry, I forgot to say that I was talking about Vision Builder AI 2013.
I simply want to export some excel data...
Example:
Green Plane
Intensity 0 - 2 Pixels
Intensity 1 - 3 Pixels
Intensity 2 - 40 Pixels
Red Plane
Intensity 0 - 4 Pixels
Intensity 1 - 7 Pixels
Intensity 2 - 80 Pixels
...and so on
@udka:
I can`t find this function in "vision assistant" under tools. I only can see "performance meter".
Is this because I am currently using the evaluation version of the programme?
I also have the student version here but I didn`t install it till now because I have some weeks left to use the evaluation version...
11-24-2014 07:58 AM
Maybe this KnowledgeBase helps you. You can save your data as Txt or CSV and open that with excel
