02-23-2015 08:35 PM
In Circle finder and Pattern matching
we are using some ROI and input setings ..
i need to save this changes while applcation running itself.
Which method i have to use ..
to save the changes
Solved! Go to Solution.
02-24-2015 03:28 AM
use xml with event based structure to read and write the selected values.
Xml example (you can write the the circular detection options datastructure directly):
K
02-24-2015 07:32 PM
02-24-2015 07:57 PM
Hi Klemen,
I am having One more Doubt .
is it possible to read paticular variable value in XML (like Config file)
S
