04-13-2005 04:26 AM
04-13-2005 05:09 AM
09-03-2005 03:46 AM
05-18-2009 01:22 PM
Hi, I just found this thread and am having a related problem. I have a 3rd-party vi that outputs and image. I would like to manipulate the image using some IMAQ functions, however when I input the image from the 3rd-party vi into any IMAQ function I get the same error as reported in the first message in this thread. Is there a way to convert the older image type to something I can use the IMAQ utilities on?
Jason
02-02-2015 10:41 AM
This is Xiaolei.
I also met this problem. Our labview version is 2013, and vision assistant is 2013. The image data type of IMAQ create is refnum, and image data type of camera setting is cluster, so I try use IMAQ image datatype to Image cluster.vi to converter the data type. But it doesn't work since IMAQ image datatype to Image cluster.vi have two elements, but the image in is the cluster of 17 elements. Please find the attachments. Would you please give me some suggestions?
Thank you so much.
Xiaolei
