06-04-2014 02:17 AM
My customer have a problem with the pulse generation on a PCIe-8237R using VBAI2013.
He configure to have a pulse on the TTL Output 0 each time there is a rising edge on the ISOInput4.
After about 20 000 pulses (12 h of production), the trigger generation stop him self (seen in the Vision Rio Tools).
Is there a way to avoid that?
06-05-2014 08:17 AM
Hi Fanfuoe,
does your customer check for timeouts in the pulse generation task?
What else does the VBAI Script do?
Is everything else working fine, when the pulse generation stops?
Melanie
06-05-2014 08:39 AM
Thank you for your response!
The vBAI script do some mesure with 2 cameras (edge basis).
If I Open / re-configure the pulse generation step, the inspection run fine again
I don't see where I can set up a timeout in the pulse generation step (see attached image)
Regards!
06-06-2014 10:30 AM
Hi Fanfoue,
I am investigating this issue as I already have a test setup with VBAI and the 8237R. In the interest of closely reproducing your setup, can you send me (or PM) the VBAI inspection?
Joseph
06-06-2014 11:22 AM
Hi Fanfoue,
I'm not entirely sure if this is could be the cause, or if it's related, but it might be worth taking a look. In Windows, there is a power management feature for Ethernet Adapters. Can you try disabling this and then seeing if the problem still occurs?
Go to Control Panel > Network and Internet > Network Connections and Edit the PCIe-8237R Adapter Properties. Deselect the option "Allow the computer to turn off this device to save power"
Again, I'm not entirely sure this is relevant, but I think it's worth trying out, as so far I have not been successful in reproducing the issue you have reported on my test setup.
Joseph
