Machine Vision
problem with thresholding
Hello guys
I am facing problem while thresholding 16 bit unsigned raw image. I am attaching my VI and snapshot of VI, along with this can you please let me know   how should we get the intensity values under the ROI box after drawing ROI over image.
I will appreciate your help
Message 1 of 18
(5,294 Views)
As you can see  you have not defined "16 bit greyscale (greyscale u16) for the imaq create of the threshold function.
Message 2 of 18
(5,289 Views)
Connection was there but I saw some sample Labview program and changed it. Now its totally back image is there, I also changed display  pallete to binary
Message 3 of 18
(5,283 Views)
is the roi a one one roi or you will want to change it multiple times?
Message 4 of 18
(5,282 Views)
Can you post your 16 bit image?
Message 5 of 18
(5,279 Views)
For the constant ROI
Message 6 of 18
(5,278 Views)
Forum is  not allowing me post RAW image. Its saying not a valid formate to upload
Message 7 of 18
(5,273 Views)
You can use iva histogram where you can define the roi
Message 8 of 18
(5,271 Views)
Try this for dynamic ROI
Message 9 of 18
(5,270 Views)
I appreciate your help .
In ROI program after taking ROI how could we get the values inside ROI matrix  in the form of array . In my previous program I tried to convert the values coming from wire after the taking ROI but it doesn't show or come up in the form of matrix.
Message 10 of 18
(5,264 Views)
