Machine Vision
pca implemetation on an image
hi, i want to perform pca on an image to get luminance image. i have done the same thing in matlab and now want to implement it in labview. but i m so confused,,, i have used imaqcolorimagetoarray vi to convert image first to array and then apply pca on it... but the array of rgb image is a 2d matrix but in matlab it is a 3d matrix,, the result of pca here and princomp in matlab is also different ... plz tell me how can i get it,,   thnx ,, here is the  code for pca in matlab
it is a function that is called in the original program ....
function [luminance] = PCA1(RGB)
% USAGE [luminance channel] = PCA1(RGB)
% INPUT
% RGB: rgb image
% OUTPUT
% luminance channel:
% from matrix representation to vector
r = RGB(:,:,1);
g = RGB(:,:,2);
b = RGB(:,:,3);
[rS cS d] = size(RGB)
rVec = r(:);
gVec = g(:);
bVec = b(:);
Ivec = cat(2,rVec,gVec,bVec);
% compute eigen vector
[eigenVec score eigenVal ts] = princomp(Ivec);
% the luminance is normalized to 1
V = eigenVec/(sum(eigenVec(:,1)));
% transformation from RGB to PCA representation
Bvec = Ivec*V
% from vector representation to matrix
luminance = reshape(Bvec(:,1),rS,cS)
plz help me as i m new in labview 😞
Message 1 of 8
(4,562 Views)
The easiest way to get the luminance plane is to call IMAQ ExtractColorPlanes or IMAQ ExtractSingleColorPlane.
Message 2 of 8
(4,554 Views)
yup i kow thai is easiest way, but problem is that i have to get luminance image by applying PCA
is there any method to apply PCA on an image directly
i have first change the image in array form but that is a 2d array but in matlab that is 3d array for an image how can i get a 3d array of an image direct.. where the 3rd dimension shows the RGB values
plz plz help me :(Smiley Sad
Message 3 of 8
(4,539 Views)
why nobody replied me ??????//
plzzzzzzzzzzzzzzzz tell me
Message 4 of 8
(4,509 Views)
You can use a combination of IMAQ ExtractColorPlanes, IMAQ ImagetoArray, IMAQ ColorImagetoArray and NI_AALPro.lvlib:Eigenvalues and Vectors (located in the Mathematics>>Linear Algebra palette) to implement the algorithm you described.
Message 5 of 8
(4,505 Views)
thnx
but what is the ni-aalprovi?
Message 6 of 8
(4,493 Views)
NI_AALPro.lvlib refers to the Advanced Analysis LabVIEW Library that the VI belongs to. You can find it in the Mathematics>>Linear Algebra palette.
Message 7 of 8
(4,488 Views)
i have done my work but here is a problem. i want to get luminance image by applying pca but the resultant image is not clear. here is the attached vi. would u plz  usee it and correct it for me?
thnx in advance..
Message 8 of 8
(4,482 Views)
