09-15-2015 02:26 AM
09-15-2015 03:06 AM - edited 09-15-2015 03:06 AM
you provided so little information that it is impossible to help you. Please provide more detailed description, attach some examples, etc...
And I suggest that you open a new thread.
K
09-16-2015 12:28 AM
My requirements in image pattern matching
1.i have to display the name of a metal part
2.programme must identify a component and show its name in screen as the component is placed below the Webcam.
suggest me solutions for it
09-16-2015 12:41 AM
take a look at (in Labview):
Help->Find Examples->Particle Classification
But first you need to ensure you have proper setup (lighting, background, perspective undistortion if needed, etc...). So that you are able to detect your object reliably.
K
09-16-2015 01:03 AM
Dear Klemen i found your reply useful but need somemore help
let me explain my problem clearly
1.i have to take a snap of more than ten automobile parts(ex pressure plates,clutch plates etc)
2.i have to save them in a particular destination with names written on the particular snaps
3. Now when i place one of the parts,whose snap shot is already taken under the webcam it must identify that part and its name should be displayed on the screen
Thankz and Regards
01-07-2017 10:21 AM
Hi Silver_Shaper,
I'm Jack.About this problem i have sothing puzzled that hope you help me to slove.To use pattern matching sample i found when the image has occured bias that couldn't find it.
Pls give me some more further infor.Ths!
01-09-2017 12:17 PM
Silver_Shaper's last post in this thread was nearly 4 years ago. It's generally a best practice to create a new thread with your question as what you're asking isn't likely to be the same as the original thread.
This also helps get you visibility on YOUR question from the community. In this case, it'd help to create a new thread and explain which sample you're using (shipping example? something you found online?), which software (LabVIEW? VBAI?), which year of the software, and a sample image showing the problems you're running into. With that, it's much easier to help you find a solution.
