04-23-2012 09:58 PM
I need count overlapping fibers and measure the length of each. The material is grated cheese. It will be spread with a vibratory feeder, but I expect lots of overlapping fibers. They will all be straight. Any ideas?
Andrew
04-24-2012 03:19 PM
Hi Andrew,
I am also working with you on this via email and your service request, I would just like to also suggest that if you have some example images to post them up here as well in case someone else on the forum has experiencing with a similar application and has some suggestions.
05-29-2012 05:36 AM
I would also be interested in an answer to this one. We are looking at glass fibre length distributions and crossing fibres pose real problems.
I have attached a thresholded image showing a typical distribution.
Many thanks,
Ben
05-30-2012 03:48 PM
Hi, there aren't any built in VIs that can achieve this directly, however it is possible to program an implementation of a straight line detection algorithm in LabVIEW, there is no built in VI to achieve this directly.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
