Thank you. My problem is the fragmentation of the memory. Another question. Are there automatic instruments to convert labview and imaq to the last versions ?
Sorry, I'm not sure what issues you may run into. Certainly anything from 7.1 and up I know should just open (at least IMAQ/Vision code) with no changes likely needed. I have never gone back as far as 5...
