06-20-2014 11:46 PM
hell0 everyone! my PCIe1433 and basler spl2048 camera has linked.But when i press the 'snap'button,the window shows"can't detect recognizable viedeo souce" ,the error code is 0xBFF6001F.Anyone else kown what's the matter?
06-21-2014 12:53 AM
Is any other session open?So it shows in max?
06-21-2014 11:28 PM
my board card and camera can find in max.but i don't konw if my camera link cable is working well.
06-22-2014 01:16 PM
Have you grabbed an image before . Do you get errors in between like timeout errors.
06-23-2014 01:56 AM
i can grab the testing image.could you tell me how to send the HSYNC signal?this is the first time i use the board card.thank you!
06-23-2014 11:15 AM
Try to unplug and plug the cables. I had issues similar like this, but when I unplug and plug the cables, it starts working again.
Good luck.
06-23-2014 08:08 PM
thank you for your reply!tank you !
02-23-2016 10:37 AM
I have two vision systems setup. One is operating fine, and the other has this error. I'm using a PCIe-1429 and Dalsa P2-1k-30 camera. Both computer/camera systems are independent and I basically copied and pasted the programs. I have used the faulting computer before and not had an issue in IMAX. Does anyone have anymore help on this one? I swapped cameras as well, and it is still not working.
