02-02-2016 06:26 AM - edited 02-02-2016 06:49 AM
Hi all,
I am new to this whole NI vision builder. I would like to know what are the steps that need to be taken to calculate an area of a component.
Thank you
02-02-2016 01:00 PM
first you have to calibrate your image and after that if you want to do your calculation automatically should use some binary action and some particle detection algorithm exist in morphology
02-02-2016 05:36 PM
The Detect Objects step located in the Locate Features tab returns the area of objects. As Hatef mentioned, you must calibrate the image first if you want to get results in real-world values.
Check out the following examples:
C:\Program Files (x86)\National Instruments\Vision Builder AI 2014\Examples\Calibrate Image Step Example.vbai
C:\Program Files (x86)\National Instruments\Vision Builder AI 2014\Examples\Detect Objects Example.vbai
Hope this helps.
Christophe
