Machine Vision
match pattern with camera
hello all,
im trying to modify match pattern vi example to work with usb camera .i want always to keep the result of matching overlayed so i add a while loop but the result is not as i want it .
can any one help me please?
(4,131 Views)
 Hey Mon3am,
You could start playing with the array functions (like the insert array.vi) and some shift registers to build something that allows you to accumulate the results in the results array each time you select a ROI.
regards,
>>Daniel C.
(4,101 Views)
im trying to use event in this example,the result is overlayed but the camera is blocked
(4,093 Views)
