06-20-2015 10:23 AM
I have been writing codes for fast real time imaging processing using Labview FPGA 2014 as well as the vision development module. The idea is to (1) acquire the image, (2) transfer the image from host to fpga target via FIFO, (3) process the pixel data through thresholding and morphological operation, and (4) finally find the centroid of the object in the image. (3) and (4) can be implemented via fpga VIs provided by the vision development module.
My question is: For image size (1024x768), what is the typical latency to process a single frame via FPGA? From some of the documents I read from the NI website, the time delay would be ~ 10 ms, which is more than I would expect. If I increase the single clock cycle frequency to 200~300 MHz, would this work?
Thanks a lot for your help.
Best,
Quan
06-20-2015 11:40 AM
Hi Quan,
In the current shipping version (14.0 or 14.5), this information is available in the help file for each FPGA VI and you have to manually add that up, based on the VIs you use.
In the upcoming 2015 release, which should be available for download from the National Instruments website very soon, this information will be available from the Vision Assistant Performance Meter. (Tools>>Perfomance Meter)
Hope this helps.
Christophe
06-21-2015 02:04 AM
06-21-2015 09:26 AM
What is your hardware? Given the fact that you're mentioning 10-tap and 100MHz, I assume that you're using a NI1473R with a 10-tap camera.
While the API only currently support 1 pixel processing, it is possible to paralellize the FPGA code to process 10 pixels at once.
We ship an example that you should be able to modify to work with 10-taps by duplicating and paralelizing some code.
C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\Vision FPGA\Image Processing with Vision Assistant on FPGA\Image Processing with Vision Assistant on FPGA.lvproj
Take a look at the FPGA VI: C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\Vision FPGA\Image Processing with Vision Assistant on FPGA\Image Processing with Vision Assistant on 1473R (FPGA).vi
I think our Product Support Engineer already helped another customer with a similar use case. I'll ask him to take a look at this post and see if he already has an example he can post.
> Another naive question, how to change the pixel bus data type from U1 to U8 in fpga VI?
Yes, you will need that if you want to do some binary morphology prior to the centroid.
In Vision Assistant, you will find the Conversion function in the Grayscale palette (just above the centroid).
In LabVIEW, it's in the Vision>>Image Management palette. It the Cast VI (IMAQ FPGA Cast.vi)
For your processing, I would recommend using Vision Assistant (or the Vision Assistant Express VI) that exposes most of the FPGA functions available in the library, and can generate the LabVIEW FPGA code for you. It handles all the 4-wire handshaking and feedback nodes for you, that can be tricky to wire in some cases.
Hope this helps.
Christophe
06-21-2015 09:42 AM
06-21-2015 10:39 AM
Hi Christophe,
Thanks a lot for your quick reponse.
You are right. I am using a PCIe-1473R with a 10-taps camera link camera. I will look into the example you mentioned. Just as Kewei posted below, the challenge is in processing all 10 pixels at once during a single time cycle. I will keep you updated about the working progress.
Awesome! that will be really helpful.
Got it!
Cheers,
Quan
06-21-2015 10:57 AM
What is the bit depth of your camera? If it's 8 bit, you can try to change the instance of the VI that returns the pixel data to 10 Tap 8 bit, use 10 local FIFOs, and duplicate the processing 10 times in parallel. That would be the way to processing 10 pixels in a clock cycle, since the API only supports 1 tap for now.
You will then need to pack the pixels to send them back to the host. I emailed the PSE, and he will hopefully answer tomorrow.
Christophe
06-21-2015 11:29 AM
>What is the bit depth of your camera? If it's 8 bit, you can try to change the instance of the VI that returns the pixel data to 10 Tap 8 bit, use 10 local FIFOs, and duplicate the >processing 10 times in parallel. That would be the way to processing 10 pixels in a clock cycle, since the API only supports 1 tap for now.
Thank you for your suggestions! Indeed, it's a 10-tap 8 bit camera. I will try to implement it!
Best,
Quan
09-01-2015 04:47 PM
Hi Quan,
Could you direct me to the NI document that mentions the 10ms delay for frame latency?
Thanks.
