Machine Vision
labview webcam video acquistion
some camera support different mode of fps and resolution for example 30 fps 300*400 / 25 fps 600*800  15 fpc 1200* 1800
when you call a camera with imagdx the default one start to act if you want to switch to different mode of camera you have to change the mode
labview example have a example of  reading a camera mode and setting the option try to test it
Message 11 of 16
(1,135 Views)
Message 12 of 16
(1,124 Views)
labVIEW VISION - Fundamentos del Procesamiento Digital de Imágenes
Una iluminación adecuada permitirá resaltar las características de interés del objeto, reducir la complejidad de la imagen y mejorar el tiempo de respuesta del  procesamiento digital. Existen variadas técnicas de iluminación,  aquellas que funcionan correctamente en el laboratorio pueden no hacerlo al momento de ser usados en el campo industrial, a continuación los principales tipos de fuente de Luz
 https://decibel.ni.com/content/docs/DOC-31879
Message 13 of 16
(1,123 Views)
Hi Hatef
my GigE camera support three modes of fps and resolution for example 250 fps 640*480 / 488 fps 640*480  1076 fps 256* 256, the system calls a camera the default one (250 fps 640*480) start to act, I want to switch to different mode.
I have tried IMAQdx Enumerate VIdeo Mode to set the height and width, but it cannot works. Also, the IMAQ video out display mode only have 640*480、800*600 and high resolution which I don't need.
So do you have any suggestions for change the camera mode?
Message 15 of 16
(960 Views)
Hi likecoco
you ask two question and I think it is better to create new topic about it
you can change camera mode with property node but any time you change it it could a bit delay on that time
for second question you have use IMAQ Remote Display Options VI
to wire quality and also use JPEG compression
Message 16 of 16
(954 Views)
