Hi all .
i have two files vbai file .
one will always capture and store it in one location . D:/ temp.bmp
i need to copy that temp.bmp file to another location for inspection...
for inspection i need the current image .. how to check whether the image whether its is current image . ?
if i use copy.vi . it is bit slower to copy.
if i use command prompt method it shoes labview memory full .
please help me to solve this issue ..
