05-11-2016 01:25 AM
I m reading a 32-bit colour image using IMAQ read options and converting it into grayscale. In, order to perform few morphological operators like dilation, filling holes and erosion. I want to convert the grayscale image to binary image. When I use the IMAQ auto2threshold 2 vi to convert it to binary image the output image is just a black but when I convert the image to array values I can see 0s and 1s. Help, me figure out why do I just get a plain black image . Using labview 2015 version and IMAQ developement module.
05-11-2016 02:10 AM
I think you simply have to right clic on your "binary image" display on the front panel, go to "palette" and select "Binary"
Epictetus
05-11-2016 02:46 AM
Thank you ! I have got the binary image now .
05-11-2016 03:01 AM
Is there any other way to get only black and white image ? So, to it better for analysing the image when I detect the corners.
05-11-2016 04:33 AM
Well... can you post the image file and your VI so we can try?
When you convert the colour image to a greyscale image, what method do you use and what plane do you extract?
Maybe you should have a look at the example for color threshold.
Epictetus
05-11-2016 05:52 PM
05-12-2016 03:15 AM
I have used the equalize vi and got a black and white image. Now, how to perfrom segmentation of the erode image ?
Thanks !
05-12-2016 03:38 AM
