04-14-2015 03:40 PM
I am using Guppy Pro F-031B firewire camera. And I am programing it with IMAQdx.
The AD converter of this camera is 14bits, and I was expecting that the counts per pixel of this camera should not exceed 2^14. In the attached picture, the maximum count for each pixel is 18132, which is larger than the 2^14. I do set a 16bits grayscale output. How did a 14bits camera generate a 16bits output usually?
My setup:
1. Ni IMAQdx with Microsoft driver.
2. VideoMode = "Format 7, Mode 0, 656 x 492"
PixelFormat = "Mono 16"
BitsPerPixel = "Use hardware value"
PixelSignedness = "un Signed"
ShiftPixelBits = "false"
AutoExposure, Brightness,Gain,Gamma=ignored
Thank you very much!
best,
wen
Solved! Go to Solution.
04-14-2015 05:16 PM
IMAQdx does not shift or stretch the data, as far as I know. Change the endianess, and see if that makes a difference.
04-14-2015 05:39 PM
John,
Thank you!
I found the problem. My camera default setting is shift the bits. So 1111 1111 1111 11 is manupulate into 1111 1111 1111 1100.
Best,
Wen
04-14-2015 06:00 PM
Yes, many cameras left shift the data so the range is identical regardless of the number of bits. This allows image processing code to run identically on any image from 10-16 bits.
