01-15-2014 06:47 AM
hi friends..
how convert a big image to parts of images? means split a jpg image to several sub imges.(this sub images can joint into that big image) any help
01-15-2014 07:15 AM - edited 01-15-2014 07:16 AM
How about converting image to array and then split array using array subset and then convert each to image??
01-15-2014 07:25 AM
i kno to convert image to array. but array to image.... facing difficulty..
thanx
01-15-2014 07:27 AM
01-15-2014 07:33 AM
hi,
i ask this qstn in different manner! can i make a big image(100 imagesin row and column) with 16 small images which repeats programically.
01-15-2014 08:17 AM
In the example, i have created two images and added them together, and the converse can be done in the same way.
01-15-2014 10:27 AM
In general you're right, but converting to array and back is not efficient way - using IMAQ Extract/IMAQ ImageToImage could be better from the performance point of view.
Andrey.
03-30-2014 11:27 PM
Hi, Udka.
I agree with Andrey. Using IMAQ Extract/IMAQ ImageToImage could be better than converting image to array. I hope you success. Good luck.
Arron
