Machine Vision
how convert a big image to parts of images? means split a jpg image to several sub imges.(this sub image can joint into that big image)
hi friends..
how convert a big image to parts of images? means split a jpg image to several sub imges.(this sub images can joint into that big image) any help
IamAKR
Message 1 of 8
(5,737 Views)
How about converting image to array and then split array using array subset and then convert each to image??
uday
Message 2 of 8
(5,733 Views)
i kno to convert image to array. but array to image.... facing difficulty..
thanx
IamAKR
Message 3 of 8
(5,729 Views)
can you explain more?
-what problem you faced? post vi if possible.
uday
Message 4 of 8
(5,727 Views)
hi,
i ask this qstn in different manner! can i make a big image(100 imagesin row and column) with 16 small images which repeats programically.
IamAKR
Message 5 of 8
(5,726 Views)
Accepted by topic author RAGIL
In the example, i have created two images and added them together, and the converse can be done in the same way.
uday
Message 6 of 8
(5,721 Views)
In general you're right, but converting to array and back is not efficient way - using IMAQ Extract/IMAQ ImageToImage could be better from the performance point of view.
Andrey.
Message 7 of 8
(5,708 Views)
Hi, Udka.
I agree with Andrey. Using IMAQ Extract/IMAQ ImageToImage could be better than converting image to array. I hope you success. Good luck.
Arron
Message 8 of 8
(5,480 Views)
